Phillip24
Dec 03, 2019Tutor
Slow Ethernet speeds (R6700)
I can't seem to get my speeds out of my router to get above 200 mbps. I'm currently paying my provider (Spectrum) for 400 mbps. Their router to my PC via ethernet and it hit 430 mbps so It dwindels d...
- Dec 04, 2019
1. What modem are you using?
2. You put that if you hook a switch to the modem, you pull full speeds. Why do you need a switch? Make sure you're going modem----router---switch.
3. I would try the factory reset and if that doesn't work, i'd try the downgrade.
Dec 04, 2019Guru - Experienced User
Phillip24 wrote:I can't seem to get my speeds out of my router to get above 200 mbps. I'm currently paying my provider (Spectrum) for 400 mbps. Their router to my PC via ethernet and it hit 430 mbps so It dwindels down to my router limiting the speed. Anybody have an idea on what is causing my router to not handle the speeds being thrown at it? I bought it last February so it's still farily new. Updated to firmware V1.0.4.84_10.0.58 today. I like this router but if I have to go back to Asus, I guess I will.
What is this "their router"?
Are you running 2x routers? If so, you'd be in a double nat which can cause issues as well as it can be "their router" limiting speeds if there's any type of qos/monitoring going on.
https://kb.netgear.com/30186/What-is-Double-NAT
After you updated firmware, did you try a factory reset? I know the R6700 rolled out support for netgear armor. Its caused some issues with multiple routers. Sometimes its resolved by a factory reset after the update and other times its taken a rollback to the firmware prior to Armor.
if you try the firmware rollback, make sure to do it over a hardwired connection and to reset afterwards.
- Phillip24Dec 04, 2019Tutor
What I mean by "their router" was Spectrum came to inspect my speeds and used their own router for the ethernet plug and the test showed the correct speed. I only have the one router. Their test confirmed my router is the culprit of the slower speeds. There is no QOS monitoring going on ( if ound on here that may have been the issue) and the I have ignored setting up the Armor setup each time it's asked to set up.
I used an old 5 port gigabit switch last night directly from the modem and my speed went up to 480 mbps which is over my contract amount. I can try and do a factory reset but it will have to wait until the end of the work day for now.
- plemansDec 04, 2019Guru - Experienced User
My modem is the E31U2V1 provided by Spectrum. I was previously using a Motorola SBG6580. My modem only has one ethernet plug on it. The reason I put the switch to the modem is then I have 4 available ethernet plugs that bypass the router. It was only to test anyways. I had an old switch so I'd thought I would try it out. I don't use the switch currently anymore. I thought I could use it as maybe a temp work-around while I continue my research.
