olllllo
Mar 08, 2022Follower
Slow internet speed on R6900v2 on ethernet
my modem is a Surfboard SB8200, I have a down load of about 900 directly into the modem. when i use the router, my download speeds stay in the 400-500 range. my up is 15.... cables all good, modem and router both less than 6 months old. through the xbox series x same issue, since it all goes through the router its slowing it down about half. why? wtf do i do?
1 Reply
Make sure to disable qos, access control, traffic monitoring, and parental controls.
If that doesn't help, try factory resetting and reinstalling. during the install, test speeds in the default configuration
