JohnDoe1111
Feb 01, 2019Aspirant
Slow internet speeds
I was told by Best Buy that for the price this was a good router for gaming on. It also is advertised as that on Netgear's website as well as in reviews on websites. I'm starting to believe I was lie...
- Feb 02, 2019
JohnDoe1111 wrote:
My only concern is now I have outdated firmware and am afraid I'm vulnerable to attacks.
It is reasonable to want to keep up with security improvements, me too, but it might be worth putting this into perspective.
Many "security fixes" are for things that are uncovered in research labs and that rarely appear "in the wild".
If it is a balance between having a router that works and one that protects me from rare security loopholes, I know which I'd opt for.
Unfortunately, Netgear rarely says what a security fix does. There is a good reason for being silent on this, revealing this information would tell hackers the holes that remain open.
I'm not into third party firmware – never had the need to go down that road – but you may find that someone has come up with a better alternative to whatever Netgear has cooked up.
By the way, if you spend any time looking at forums that support other makes of router you will find depressingly similar messages. After all, they all use the same small range of network chips. The main difference is that Netgear has a more active community than most, with many more unpaid volunteers trying to provide genuine help for fellow users.
myersw
Feb 01, 2019Master
Still within the return window do it and get something from a different vendor.
Unfortunately Netgear engineers are out wandering in a wilderness in Tiawan and coming up with version after version of less then stellar firmware.
Netgear used to be my favorite and recommended routers, no more.
michaelkenward
Feb 02, 2019Guru - Experienced User
Health warning to JohnDoe1111 , this advice comes from someone who regularly states that they do not allow Netgear hardware on their network. They hang around here so that they can bang on about this.
You might like to bear that in mind when deciding how much weight to attach to their advice on how to use your own Netgear stuff.
- myerswFeb 02, 2019Master
He also is helpful to Netgear users based on his kudos and problems solved numbers.
He does assist folks not just blindly suggest going elsewhere, as you well know. .
