usrNighthawk
Jul 18, 2016Aspirant
Slow link speed on my 2.4 band for my Laptop during negotiation?
So, I ordered my Nighthawk lastnight, and somehow got it delivered this morning by 10 AM (yes on a Sunday), deliver within around 12 hours of buying it. Wow, great huh, I was shocked and like a kid ...
- Jul 18, 2016What's the model of the Wi-Fi adapter on your laptop? I'm guessing that it is single stream 802.1n. Such an adapter can only get a link speed of 150 Mbps when using a 40 MHz wide channel. Were you forcing your old router to use 40 MHz? You can try disabling 20/40 MHz coexistence in advanced wireless settings on the Nighthawk. There's no guarantee that those will work. Note: Using 40 MHz channels isn't very neighbor friendly because it consumes 2/3 of available spectrum at 2.4 GHz.
TheEther
Jul 18, 2016Guru
usrNighthawk
Jul 19, 2016Aspirant
Another side question, can you suggest why windows firewall is asking that Netgear's Genie app would be asking for firewall acess on a Public network? I know this is not what my original question was, and that this is not what these forums are typically used to or allow, but just thought it was worth asking.
Thanks in advance for any help/assistance/guidance you could provide on either of or both of these items.
