WindfallNL
Aug 12, 2019Aspirant
Slow local traffic with XR500
Setup : internet modem -> router (XR500) -> computer 'M' -> VM on 'M'. VM runs web server. Web server has a 5 MB gzipped page for index.html. A domain name 'D' is mapped to the WAN address of the mod...
- Aug 13, 2019
WindfallNL wrote:
Well, the XR500 is a Nighthawk, and it is a Wifi router, so ... maybe there shouldn't be so many sections.
I can't disagree with that.
WindfallNL wrote:
As if answers for one, who have one, wouldn't apply for another, who don't have the exact same model.
The separate section exists because the XR series uses DumaOS as the operating system. This comes from a different outfit. The people who created DumaOS monitor that area and may miss messages that crop up here.
michaelkenward
Aug 13, 2019Guru - Experienced User
You might get better and quicker replies, and find other answers, over in the appropriate section for your hardware:
Nighthawk Pro Gaming Routers - NETGEAR Communities
- WindfallNLAug 13, 2019Aspirant
Well, the XR500 is a Nighthawk, and it is a Wifi router, so ... maybe there shouldn't be so many sections. As if answers for one, who have one, wouldn't apply for another, who don't have the exact same model.
Ayway, cross-posted it now.
- FURRYe38Aug 13, 2019Guru - Experienced User
NG created a Gaming router section for ALL XR routers as they do differ from other NG Nighthawk R series routers.
- IrvSpAug 13, 2019Master
WindfallNL wrote:Well, the XR500 is a Nighthawk, and it is a Wifi router, so ... maybe there shouldn't be so many sections.
Semantics. Actual name is "Netgear Nighthawk XR500 Pro Gaming Router", and this 'section' is "Netgear Nighthawk Routers". Not sure how you got here, but if you came in via COMMUNITY, the CONNECTED HOME, the first one is NIGHTHAWK GAMING ROUTERS, then WIFI ROUTERS (with 3 different forums, one this one).
You really want to be in the correct forum. First in the particular case the OS it is running, it is using NetDuma's DumaOS software, and there are people from NetDuma monitoring that forum. That and other uses of the same h/w that can possibly assist.
Not to worry, you were not the first to be in the wrong forum, and not going to be the last either.
- michaelkenwardAug 13, 2019Guru - Experienced User
