palbin
Jun 07, 2021Aspirant
Slow Netgear Nighthawk X6 AC3200
When I connect my computer directly to internet with ethernet cable I get speed 500/500 but when I instead go through my Netgear router (ethernet cable from computer to router and ethernet cable ...
microchip8
Jun 07, 2021Master
Which firmware version? (not "the latest")
Do you have QoS or TrafficMeter enabled?
- plemansJun 07, 2021Guru - Experienced User
Along with qos/traffic meter, also make sure access control and parental controls are disabled and then reboot the router.
If that doesn't help, try a factory reset and reinstall. Test it in its default configuration.
