charlesmccune
Mar 20, 2021Follower
slow Network Traffic between switch and Linksys Router
Ok here's the Problem. When I connect My Linksys WRT 1900 ACS to One of the 4 Copper 10GB, 1G, 100, 10 Ports. It connects at the 1G speed because that's what the Router is. The switch will link up t...
michaelkenward
Mar 21, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but the XSM7224S switch is nothing like a router so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
I will ask the Netgear moderator to move your message.
