hunterjohn73056
Jun 10, 2020Tutor
Slow R8000 slow ethernet speeds
My internet service provides 100mbs to the modem, which I have verified. However, I can't get more than 30mbs from the router through ethernet connections. I have tried different cables and computers...
- Jun 11, 2020
I solved the problem by logging into the advanced router settings and disabling QoS. Now getting 104 mbps down and 13mbps up.
Jun 10, 2020Guru - Experienced User
1. what modem is it connected to?
2. what firmware is on the r8000?
3. Did you recently upgrade your speed? If so, I'd start by factory resetting and manually reinstalling (not from backup). Reason why is I've read of old qos settings being retained even though qos was disabled and the router rebooted.
