dimab0's avatar
dimab0
Follower
Jan 06, 2017
Slow speed suddenly on R8000
I've been using this router for about 1.5 years now. As of 2 days ago, my download speed seems capped to 7Mbps, while the upload goes up to 20Mbps. Directly through out wired connection in the wall, ...
  • JamesGL's avatar
    Jan 12, 2017
    Hi dimab0,
    1. What is the firmware version of the router?
    2. Disable QoS and check if the same.
    3. Use a different ethernet cable.
