jjdv
Sep 13, 2021Follower
slow speed with vpn enabled on 6700v3
With ExpressVPN enabled on the router I get 34 Mbps. If I disable the VPN the speed goes up tp 93 Mbps !!! Wow! Anyone have any ideas as to what has the issue, is it the router or the ExpressVP...
Sep 13, 2021Guru - Experienced User
as well as expressvpn is 3rd party firmware. You'd have to check with them with issues.
