User0000
Jul 09, 2021Aspirant
Slow speeds with CM2000 modem and R7000 router
Modem: Netgear Nighthawk CM2000 (not sure why it's not identifying it in the "model" tag) Router: Netgear Nighthawk R7000 Firmware Version: V1.0.11.100_10.2.100 OS: Windows 10 Pro When I plug ...
Jul 09, 2021Guru - Experienced User
1. you don't have the latest firmware. the R7000 is currently on 1.0.11.123. Try installing that over a hardwired connection, then factory reset/reinstall the router.
2. have you checked the cables to ensure you have a gigabit connection? I've seen sketchy cables default back to the 10/100mbps connection
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
User0000
Updated and no dice. My current cables were a 2 for 1 special on amazon, so I just ordered some better ones, and will update when they arrive. Thank you for the heads up about the software. So dumb the auto-update wouldn't recognize it, yet its right there on their website.
- plemansJul 09, 2021Guru - Experienced UserDid they show 10/100mbps connection or gigabit?
