ericseaberg
Apr 27, 2020Tutor
Slow throughput from Gigabit ISP
I purchased my Nighthawk R9000 from FlashRouters with DD-WRT firmware installed and have had nothing but issues with its implementaion. I've been back-n-forth many times with the people there, and h...
- May 05, 2020
Glad you have a working r9000. I ran DD-WRT on various routers starting with a Linksys WRT54G back in 2006. Was a solid firmware for the most part and lots more knobs to twist.
Apr 27, 2020Guru - Experienced User
did you try the stock firmware?
Or Voxel's 3rd party firmware?
ericseaberg
Apr 27, 2020Tutor
Thanks for the reply... and, NO, I haven't tried the stock firmware. I purchased the Nighthawk from FlashRouters presetup with DD-WRT and my ExpressVPN credentials.
I really just want to know if anyone else has had throughput issues with the stock firmware.
What is the advantage with Voxel over DD-WRT?
- plemansApr 27, 2020Guru - Experienced User
1. the firmware you've got is made by a company to work with its vpn setup. Their main goal is to sell vpn service and their setup, not support/update firmwares. Plus it always leaves them an "out" like "its netgear's hardware, its their fault" or "its because of how dd-wrt works". Their main goal isn't how well the router runs.
2. voxel's firmware has been pretty solid and well reviewed for 3rd party firmwares. its free and has been pretty popular for netgear devices.
3. The stock firmware does support gigabit. I don't have a R9000 so I can't personally attest to it hitting gigabit but I've helped others get to gigabit. the main recommendations I have are to avoid access control, qos, traffic monitoring if you're having issues.
- labattApr 27, 2020Mentor
I don't think that DD-WRT supports CTF in all their firmware. That might explain the slow speed. Should you decide to install Netgear firmware, be careful with how you do it. Normally DD-WRT has a back to OEM file for the initial Netgear install. Just trying to install Netgear OEM firmware over DD-WRT does not normally work in my experience.
- ericseabergApr 27, 2020Tutor
Thanks for the replies, guys. I had been in contact with FlashRouters and they sent me a link to get this:
http://www.downloads.netgear.com/files/GDC/R9000/R9000-V1.0.5.8.zip
Look correct? Sounds like that the way I'm going to have to go, which is fine by me. I was having so many issues with ExpressVPN disconnecting a lot and things losing connections all over the house.
I may also take a quick look at Voxel's firmware that plemans suggested.
