ericseaberg
Apr 27, 2020Tutor
Slow throughput from Gigabit ISP
I purchased my Nighthawk R9000 from FlashRouters with DD-WRT firmware installed and have had nothing but issues with its implementaion. I've been back-n-forth many times with the people there, and h...
- May 05, 2020
Glad you have a working r9000. I ran DD-WRT on various routers starting with a Linksys WRT54G back in 2006. Was a solid firmware for the most part and lots more knobs to twist.
Apr 27, 2020Guru - Experienced User
yes, don't use your ip tables or backups
ericseaberg
May 05, 2020Tutor
I decided NOT to revert back to OEM firmware and found a setting within DD-WRT that enables the "Shortcut Forwarding Engine". I now have full throughput on wired and wireless devices. No more VPN, which is totally fine with me. I need the speed and it's working now.
Thanks for all of the help.
- labattMay 05, 2020Mentor
