Th3-0n3
Jan 12, 2019Tutor
Slow wifi speed.
I have a netgear cm1000 for the modem connected to my netgear nighthawk R7800 router my service is with comcast/ xifnity 400 download 10 upload. When I connect my PC to the modem I get the full 400. W...
- Jan 12, 2019
WMM should be enabled, not disabled
you should roll back the firmware to .52 as both .58 and .60 have wifi problems NG needs to address
microchip8
Jan 12, 2019Master
Th3-0n3
Jan 12, 2019Tutor
I just want to say thanks for replying and WMM I disable yesturday since gaming online got really bad and I read in a netgear page that it helps to disable this. I roll back to the when I get home now should I do a factory reset before i roll back or roll back to the .52 then a factory reset?
