Th3-0n3
Jan 12, 2019Tutor
Slow wifi speed.
I have a netgear cm1000 for the modem connected to my netgear nighthawk R7800 router my service is with comcast/ xifnity 400 download 10 upload. When I connect my PC to the modem I get the full 400. W...
- Jan 12, 2019
WMM should be enabled, not disabled
you should roll back the firmware to .52 as both .58 and .60 have wifi problems NG needs to address
Th3-0n3
Jan 12, 2019Tutor
I hope this fixes the problem I was about to buy a new router yesturday but man I'll save alot it it works.
myersw
Jan 12, 2019Master
Two things. Voxel firmware runs well on the r7800 and he has done some fixes that Netgear has not yet. Good firmware in my experience.
Second thing. Should you decide to get a different router I would strongly urge you look someplace other then Netgear. Netgear really does not seem to have their act together regarding firmware. All releases seem to have major problems right now.
- Th3-0n3Jan 12, 2019TutorThanks I'll check that out also what other router would you recommend in case I need to get one?
- myerswJan 12, 2019Master
Th3-0n3 wrote:
Thanks I'll check that out also what other router would you recommend in case I need to get one?Right now I have gone up to the next level and running Ubiquiti Unifi gateway (router) with Unifi AP's these then to be a more comercial product set and need some network knowledge to setup. Therefore I am not really running what I would recommend to the average Netgear forum member. I have over 20 years experience in routers and networks.
I watch forums folks have had good luck with Asus RT-AC86U similar to the r7800 and some Linksys. That is about all I have in the recommended area. Sorry I cannot be more specific.
- Th3-0n3Jan 12, 2019TutorThanks I'll keep that in mind.
