DesertRat66's avatar
DesertRat66
Slow WiFi speed from AC4000 X6S
Hi; I have the R8000P (AC4000) and about two weeks ago noticed my WiFI speed dropped precipitously from between 300-400Mbps to about 150Mbps. I am on a fiber gigabit plan through my ISP provider.  I...
  • FURRYe38's avatar
    Yes, or 192.168.1.1 or the routers IP address you may have configured on it. There is a FW update section in the routers web page where you navigate to where the file is and select it, then the web page does the rest.
    Safari, FireFox or Opera browser will help you get to the Routers web page and update FW.
    https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
    Should not impact current reservations.
