HanYol0
Dec 21, 2016Aspirant
Slow Wifi Speeds Nighthawk x10
Just upgraded my router from the Asus RT-AC68U which was giving me my rated speed through time warner wired or wireless and now with this X10 i just set up today and installed newest FW as advised to...
- Jan 09, 2017
Hi HanYol0,
As long as the modem provides the correct speed from your ISP, then the router should be able to work fine.
Dec 21, 2016Guru - Experienced User
What ISP Modem service link speeds UP and Down do you have?
Did you perform a factory reset after the FW update and set up from scratch?
What wireless modes are you using?
Try Single mode N on 2.4Ghz and 5Ghz with WPA2 and AES only.
What client device are you using to test wireless speeds?
Were you seeing better results with the Asus router using same device?
FYI regarding your SB6190:
https://www.dslreports.com/forum/r31122204-SB6190-Puma6-TCP-UDP-Network-Latency-Issue-Discussion
HanYol0
So i changed the channel from auto on 2.4ghz to 2 and 6 each with speedtests in between and was about to get close to 200 down. Being on auto, is the limiting factor here interferance? 2 and 6 have to work together to provide my speed?
