HanYol0
Dec 21, 2016Aspirant
Slow Wifi Speeds Nighthawk x10
Just upgraded my router from the Asus RT-AC68U which was giving me my rated speed through time warner wired or wireless and now with this X10 i just set up today and installed newest FW as advised to...
- Jan 09, 2017
Hi HanYol0,
As long as the modem provides the correct speed from your ISP, then the router should be able to work fine.
Dec 26, 2016Guru - Experienced User
Set WPA2 and AES only with Speed up to 347Mbs and channel 11 then test on 2.4Ghz. I presume you don't have a client that can connect at 800Mb on 2.4Ghz, if not then leave at 347Mbs.
- HanYol0Dec 27, 2016Aspirant
Thanks, i will try this out tom when i get home and follow up.
- FURRYe38Dec 28, 2016Guru - Experienced User
:smileyhappy:
- HanYol0Dec 30, 2016Aspirant
So after doing a little rearranging with this router and modem im unable to get above 100mb down with either direct connection or wireless. I tried setting 2.4 t0 387 and channel 11 but no improvement. I've done the following:
Restored factory settings on router
replaced cat 5 cable from router to desktop
tried diff ports on router
Using a long coax cable i just bought to help with the new location. Cable is about 30 feet long..shouldnt be the issue? ohms out fine.
from the modem directly to the computer i get the same low speed. Called up oceanic and they said everything looks fine with no issues showing up. Had them do a remote restart of my connection and same result.
ugh, i thought moving to this new r9000 would be a breeze.
