HanYol0
Dec 21, 2016Aspirant
Slow Wifi Speeds Nighthawk x10
Just upgraded my router from the Asus RT-AC68U which was giving me my rated speed through time warner wired or wireless and now with this X10 i just set up today and installed newest FW as advised to...
- Jan 09, 2017
Hi HanYol0,
As long as the modem provides the correct speed from your ISP, then the router should be able to work fine.
HanYol0
Dec 27, 2016Aspirant
Thanks, i will try this out tom when i get home and follow up.
Dec 28, 2016Guru - Experienced User
:smileyhappy:
- HanYol0Dec 30, 2016Aspirant
So after doing a little rearranging with this router and modem im unable to get above 100mb down with either direct connection or wireless. I tried setting 2.4 t0 387 and channel 11 but no improvement. I've done the following:
Restored factory settings on router
replaced cat 5 cable from router to desktop
tried diff ports on router
Using a long coax cable i just bought to help with the new location. Cable is about 30 feet long..shouldnt be the issue? ohms out fine.
from the modem directly to the computer i get the same low speed. Called up oceanic and they said everything looks fine with no issues showing up. Had them do a remote restart of my connection and same result.
ugh, i thought moving to this new r9000 would be a breeze.
Could this latest FW be the issue?
- StephenBDec 31, 2016Guru - Experienced User
Your wired speeds are normal, correct? So I don't understand why you spent so much time playing with cables.
First try the factory reset suggested earlier.
If that doesn't help, then try downgrading to the earlier FW, resetting again, and then retesting the speed.
