HanYol0
Dec 21, 2016Aspirant
Slow Wifi Speeds Nighthawk x10
Just upgraded my router from the Asus RT-AC68U which was giving me my rated speed through time warner wired or wireless and now with this X10 i just set up today and installed newest FW as advised to...
- Jan 09, 2017
Hi HanYol0,
As long as the modem provides the correct speed from your ISP, then the router should be able to work fine.
HanYol0
Dec 31, 2016Aspirant
Stephen,
That was the original problem but now I can't get above 100mbs down through a wired connection. This is with original router and r9000. Swapped sb6190 to 6183 thinking it was the culprit and nothing changed. Time Warner did checks on their end for signals and said everything was fine.
Tech coming out Tuesday now but I feel like something weird is going on. I had good down speed with original Asus router and sb6183 before deciding to upgrade two weeks ago:(
- FURRYe38Jan 02, 2017Guru - Experienced User
If you have swapped modems and tested a different router, then I might presume there maybe an issue with your specific R9000 unit. Might try another one if you have a local store with a refund policy.
HanYol0 wrote:
Stephen,
