HanYol0
Dec 21, 2016Aspirant
Slow Wifi Speeds Nighthawk x10
Just upgraded my router from the Asus RT-AC68U which was giving me my rated speed through time warner wired or wireless and now with this X10 i just set up today and installed newest FW as advised to...
- Jan 09, 2017
Hi HanYol0,
As long as the modem provides the correct speed from your ISP, then the router should be able to work fine.
HanYol0
Jan 08, 2017Aspirant
So I had time Warner come out since I couldn't get the 300 down speed direct through modem and wireless. They swapped out between my two modems sb6183 and 6190 and then put their modem on and speeds were erratic at first but then hit 320ish.
So now on 5ghz I can hit above 320ish most of the time.. Wondering if maybe my ISP was secretly limiting my bandwidth..
Are there any settings on this r9000 recommended to be left off?
JamesGL
Jan 09, 2017NETGEAR Employee Retired
Hi HanYol0,
