AR_0991
Jun 02, 2022Tutor
Slow WiFi Speeds (R6700)
I recently noticed slower speeds over my wifi network. I ran a speed test and saw that I was getting <50% of the speed I am paying for (i.e., ~200 Mbps when I pay for 500 Mbps). I had Cox (my interne...
Jun 02, 2022Guru - Experienced User
Do you get full speeds when hardwired in?
What device are you using to test speeds?
What firmware is on it?
Are you using traffic monitoring, qos, access control, or parental controls? (if so, disable them)
Is ipv6 enabled?
- AR_0991Jun 02, 2022Tutor
Thanks for the speedy response plemans.
To answer your questions:
- Yes, I get full speeds when hardwired
- I have used multiple devices to test the speed (e.g., my Nighthawk App, getmyspeed)
- The firmware version is: V1.0.4.22_10.0.95
- No, I am not using traffic monitoring
- No, I do not have any QoS enabled
- Access control is turned off
- Parental controls are not enabled
- IPv6 is disabled
Hope that helps narrow it down.
Thanks again!
- plemansJun 02, 2022Guru - Experienced User
what actual devices are they?
225mbps is pretty amazing for a 1x1 antenna device. its a little under performing for a 2x2 device.
Keep in mind, 2.4ghz is slow and you're not going to even close to 5ghz speeds with it.
how far from the router are you? 5ghz speeds drop off quicker than 2.4ghz but they have a higher starting point.
- AR_0991Jun 03, 2022Tutor
plemans, thanks again for the help.
If you're asking which derives are running slow, it's my laptop, phone, and TV streaming.
And it's a 2x2, which is part of the reason it's a bit frustrating. I can be standing right in front of the router with my device and still not break 225 Mbps.
