KPatel
Aug 05, 2022Aspirant
Slow WiFi troubleshooting
I was hoping someone could help me troubleshoot my slow WiFi speeds. When I directly connect to my router via ethernet, I get 700mbps that I'm supposed to get by my ISP. My wifi adapter on windows sh...
Aug 05, 2022Guru - Experienced User
Would be helpful to know what NG product and model # you are referring too...
- KPatelAug 05, 2022Aspirant
Yes, you're right. My apologies.
My router: Nighthawk X10 – AD7200 (R9000)
I also get a new wifi adapter thinking that would solve the issue (Nighthawk AC1900, A7000)
- plemansAug 05, 2022Guru - Experienced User
Try factory resetting.
During the install, make sure to leave qos, access control, parental controls, and traffic monitoring all disabled.
- wcalifasAug 05, 2022Prodigy
You'll never get the same speeds over wifi no matter what router you have, Only wired will give you what you pay for, just and FYI.
