KPatel
Aug 05, 2022Aspirant
Slow WiFi troubleshooting
I was hoping someone could help me troubleshoot my slow WiFi speeds. When I directly connect to my router via ethernet, I get 700mbps that I'm supposed to get by my ISP. My wifi adapter on windows sh...
KPatel
Aug 09, 2022Aspirant
Thanks for all the help! I did a factory reset of the router but it didn't make much of a difference.
I know that the wifi speeds would be slower than the router speeds but I've had faster speeds on my wifi in the past. I've used other devices and had the same speed. My neighbors speedtest gets up to 300-350mbps at his house (he has the same ISP and plan as me) but only caps out at 200 whenever he comes over.
Anyway, thanks for everyone's input and help, I really appreciate it!
Aug 09, 2022Guru - Experienced User
How far from the router are you?
Did you try other devices?
What firmware version is on the router?
do you have IPv6 enabled?
What modem/gateway is the router connected to?
