yelnod66's avatar
May 11, 2016
Slow wired internet speed
Hello,   I am having trouble with my wired internect connection while using this router.  My set-up is as follows:   MODEM > ROUTER > ETHERNET SWITCH > PATCH PANEL > ETHERNET WALL PLATE   So, I...
  • TheEther's avatar
    TheEther
    May 11, 2016
    Try disabling Downstream QoS and retest.  Sometimes, but not always, QoS is more trouble than it's worth.
    You will find keyword blocking by logging into the R7000.
    Also, consider uninstalling Netgear Genie from your PC.  While it can be a nifty way of managing your router, it's not required.  I've heard that it can sometimes interfere with proper operation of the PC.
