JerseyBiker
May 19, 2020Aspirant
Slow wired speed on Xfinity gigabit service
I just upgraded my broadband service on Comcast to their Gigabit speed service. I first replaced my Netgear CM500 modem because Comcast said it wasn’t capable of the faster speed. I purchased an Arri...
- May 19, 2020
If possible restore the stock Netgear firmware.
While I have not used tomato in a long time, the last time I checked, it does not seem to offer CTF on R7000, in which case WAN to LAN throughput will be low.
labatt
May 19, 2020Mentor
This is a Netgear only forum. You will not get much help when using Tomato. Have you asked on the tomato forums?
- JerseyBikerMay 19, 2020Aspirant
labatt wrote:This is a Netgear only forum. You will not get much help when using Tomato. Have you asked on the tomato forums?
https://www.linksysinfo.org/index.php
Thanks, I was hoping it didn't have anything to do with the firmware. I always had issuses with stock Netgear firmware. Never any issues with Tomato. I'll take you advice and ask the question on a Tomato forum, but they are not organized like here. If I can't find a solution I'll first try going back to stock first, and using the Xfinity XB6-T unit.
