Pete2453
Feb 10, 2021Aspirant
Slow wired speeds R8000
Long story short, have done resets changed cables (all cat 7) fresh reinstall of firmware etc etc, multiple online chats with support and telephone calls. bout this and the 1150v modem, am with X...
- Feb 15, 2021
Final update:
R8000 has the latest firmware on it V1.0.4.68_10.1.75
MTU set to 1500
QOS, traffic, etc all set to disabled
Now getting 935 mbs wired and wireless is fantastic.
Solution: Replacement CM1150V modem
Feb 11, 2021Guru - Experienced User
1. What actual firmware version are you on? "the latest" isn't always the best with the R8000
2. What fixed it before?
3. With the r8000, if you have speeds >250mbps, make sure qos, traffic monitoring, access control, and parental controls are all disabled.
If they were enabled, and disabling/rebooting doesn't fix the speeds, then try a factory reset and clean install (not from backup). Do not enable those service.
- Pete2453Feb 11, 2021Aspirant
Hi thanks for your response, I am away from my router at the moment but,
the firmware is the latest for this router on one of the online chats sessions I reset to factory and uploaded the firmware from my pc as directed by the support person.
the first session fixed it by changing the mature size to 1472, turning access control off and ensuring qos was off. Also a power cycle. Was told may take a couple of hours upto 10 to get the full benefit.
to answer your last point, have done a factory reset made sure everything that should be off is off etc and reloaded the firmware from my pc on hardwire.
later today I have an xfinity tech come out again and check every thing thee end which am sure nothing has changed since Sunday and also they are bringing another modem so we can fault check that way as well. If tat works then I can only assume that there is an issue with the netgear modem and router.
will keep all updated once again appreciate the help
- plemansFeb 11, 2021Guru - Experienced User
With the R8000, the latest isn't the best.
And those 4 settings can cause your speeds to stay in the 200mbps range.
Version I'd recommend would be 1.0.4.28
try installing that version, do a factory reset, and then a clean install (not using a backup). Again, make to to leave access control, traffic monitoring, qos, and parental controls all disabled
- Pete2453Feb 11, 2021AspirantI will try that later today and update the results of this and the xfinity visit
Thanks
