Pete2453
Feb 10, 2021Aspirant
Slow wired speeds R8000
Long story short, have done resets changed cables (all cat 7) fresh reinstall of firmware etc etc, multiple online chats with support and telephone calls. bout this and the 1150v modem, am with X...
- Feb 15, 2021
Final update:
R8000 has the latest firmware on it V1.0.4.68_10.1.75
MTU set to 1500
QOS, traffic, etc all set to disabled
Now getting 935 mbs wired and wireless is fantastic.
Solution: Replacement CM1150V modem
Pete2453
Feb 15, 2021Aspirant
Latest update
Have receievd a replacement modem CM1150V when computer connected directly to modem now getting 900+mbs so happy there.
Reset the R8000 factory settings made sure everything that should be disabled is ie traffic monitor etc. MTU is set to 1400 (did ping tests and then added 28)
The download speeds are now stable at 350mbs, but supprised still losing 600 odd mbs somehow
Any thoughts?
Pete2453
Final update:
MTU set to 1500
