Tylerlead222
Jan 14, 2022Aspirant
Slower speeds on router than on modem. Nighthawk AC1750 r6400v2
I just purchased an Arris surfboard8200 and a Nighthawk 1750 6400v2 and have them all set up through Suddenlink. I have a gigabit plan through them and would get 700-800 Mbps down on our old modem/ro...
Jan 14, 2022Guru - Experienced User
make sure qos, access control, traffic monitoring, and parental controls are all disabled.
If they were enabled and disabling them and rebooting the router doesn't increase speeds, then try a factory reset.
make sure during the install to leave those disabled.
Tylerlead222
checking routerlogin shows all of those as disabled by default already. I still can't turn armor off for some reason though despite the app saying that it's disabled. It's still reporting scan results. I'll reboot my router and see if that does anything, if not, then I'll factory reset.
- Tylerlead222Jan 14, 2022Aspirant
I'm not sure what happened now but speeds tanked even worse than before. This is abysmal.
- plemansJan 15, 2022Guru - Experienced User
When you give vague statements, it doesn't help.
Tanked after a factory reset?
Tanked after disabling those features?
And what speeds did they tank to?
And how were you testing? wired? wireless?
2.4gh? 5ghz?
Details are key
