Tylerlead222
Jan 14, 2022Aspirant
Slower speeds on router than on modem. Nighthawk AC1750 r6400v2
I just purchased an Arris surfboard8200 and a Nighthawk 1750 6400v2 and have them all set up through Suddenlink. I have a gigabit plan through them and would get 700-800 Mbps down on our old modem/ro...
Tylerlead222
checking routerlogin shows all of those as disabled by default already. I still can't turn armor off for some reason though despite the app saying that it's disabled. It's still reporting scan results. I'll reboot my router and see if that does anything, if not, then I'll factory reset.
Tylerlead222
I'm not sure what happened now but speeds tanked even worse than before. This is abysmal.
- plemansJan 15, 2022Guru - Experienced User
When you give vague statements, it doesn't help.
Tanked after a factory reset?
Tanked after disabling those features?
And what speeds did they tank to?
And how were you testing? wired? wireless?
2.4gh? 5ghz?
Details are key
