akstanislaus
May 31, 2021Follower
smart bulb
How do I set up smart bulb on my dual router ( Its set for 5 ghz) and bulb only supports 2.4ghz?
Jun 01, 2021Guru - Experienced User
Your router supports both bands.
The trick is to make sure your phone is connected to the 2.4ghz during setup of the bulb.
It shouldn't matter but because of lazy coding, the phone sometimes needs to be on the same band as the device you're setting up.
