akstanislaus
May 31, 2021Follower
smart bulb
How do I set up smart bulb on my dual router ( Its set for 5 ghz) and bulb only supports 2.4ghz?
PinoyJim
Jun 23, 2021Aspirant
This is how I finally got everything to work fast and very easily the way it did when you first installed it on your old router.
I used the browser to go the router's settings by entering 192.168.1.1 on the URL.
Under the Wireless menu option on the left, turn off the ENABLE 5G option.Change the 2.4Ghz channel to 1. Click APPLY and wait for the settings to get applied.
Install your bulbs as before and things should work the way they should now. I was also able to get my wireless HP Laserjet Pro 100 to connect after changing the settings.
Once the devices are reconnected, you can turn on the ENABLE 5G back and the devices should continue to work.
