larrylato
Oct 19, 2020Aspirant
Smart Connect with Extender
Does a Netgear EX3700 work with Smart Connect setting on the R8000? After switching to Smart Connect, all my wireless bands list as one SSID but the (EXT) bands still show as "Available Networks"!
- Nov 10, 2020
It tends to fall in line with those devices that support mesh. This article: https://kb.netgear.com/000044734/How-do-I-enable-or-disable-Smart-Connect-on-my-Nighthawk-Mesh-WiFi-Range-Extender
shows an "applies to" for devices on the right side. all those have smart connect.
theGraduate
Nov 10, 2020Tutor
Is there a Netgear extender model that can support Smart Connect?
Thanks again.
plemans wrote:No it doesn't. Its a base model dual band range extender.
Nov 10, 2020Guru - Experienced User
