sysdom
Dec 18, 2017Aspirant
Smart connect
Re: Smart Connect Model:EX8000 Can you use one SSID for the 2.4 GHz, 5Ghz and 5GHZ-2 wireless network on the NightHawk X6S (AC3000) Tri-Band WiFi Range Extender?
- Dec 19, 2017
Then enable the smart connect I have posted the need munual above in a earler post I believe under set up.
William10a
Dec 19, 2017Master
sysdom wrote:Re: Smart Connect Model:EX8000
http://www.downloads.netgear.com/files/GDC/EX8000/EX8000_UM_EN.pdf
Above is the link for the manual
The answer is yes if smart connect is enable on the range extender saw it in the manual if thats what you want.
- sysdomDec 19, 2017AspirantLet me rephrase the question- can you setup one SSID on the Nighthawk X6S (AC3200) for the 2.4GHz, 5GHz and 5GHz-2 wireless network and use it with the Nighthawk X6S Extender (EX8000)?
- William10aDec 19, 2017Master
Yes disable the smart connect on the extender then you you will have three bands each with their ownn ssid it is the manual as well
- sysdomDec 19, 2017AspirantI want to use the same SSID for the three bands.
Example -
Juno34 =2.4 GHz
Juno34 =5GHz
Juno34= 5GHz-2
