sysdom's avatar
sysdom
Smart connect
Re: Smart Connect  Model:EX8000 Can you use one SSID for the 2.4 GHz, 5Ghz and  5GHZ-2 wireless network on the NightHawk X6S (AC3000) Tri-Band WiFi Range Extender?
  • William10a's avatar
    William10a
    Dec 19, 2017
    Then enable the smart connect I have posted the need munual above in a earler post I believe under set up.
