sysdom
Dec 18, 2017Aspirant
Smart connect
 Re: Smart Connect  Model:EX8000  Can you use one SSID for the 2.4 GHz, 5Ghz and  5GHZ-2 wireless network on the NightHawk X6S (AC3000) Tri-Band WiFi Range Extender?
- Dec 20, 2017
Then enable the smart connect I have posted the need munual above in a earler post I believe under set up.
sysdom
Dec 19, 2017Aspirant
I want to use the same SSID for the three bands.
Example -
Juno34 =2.4 GHz
Juno34 =5GHz
Juno34= 5GHz-2
Example -
Juno34 =2.4 GHz
Juno34 =5GHz
Juno34= 5GHz-2
William10a
Dec 20, 2017Master
