franker2407
Aug 29, 2022Aspirant
Smart Wifi Router R7000 - Laptop Installation
I purchased a new laptop. The netgear app is working on my cell phone. However, when I select the Netgear network on my laptop, it does not recognize my password (PW). I tried both the PW that came w...
- Aug 29, 2022
You have put yourself into what they call a double NAT situation. Not good. Read up on it here:
https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
The easiest solution is to access your router configuration and change the operating mode from router to wired access point. Then you can connect your router to your ONT via Ethernet cable. There are other options you can research later.
Be careful not to set your new router too physically close to the ONT as the Wi-Fi signals will interfere. Eight to ten feet is good if you can get it for separation.
franker2407
Kitsap, I have Windows version 11. Thanks for your response. If it helps, it is an HP Envy laptop.
Kitsap
Aug 29, 2022Master
Go to Settings -> Network & Internet -> Status -> Properties. Verify your Network profile is classified as Private. If not, change it to private. Recommend you restart your computer before you try to reconnect.
The default network classification for Windows 11 is public. This usually means no user names and passwords.
- franker2407Aug 29, 2022Aspirant
Switched from public to private. Still doesn't recognize the PW. Any other suggestions. I tried to enroll in Netgear's extended warranty coverage, but the email it was supposed to send never arrived. Very frustrating.
- KitsapAug 29, 2022Master
Have you connected to Wi-Fi anywhere with this computer?
Go up into the Windows Tools section and try the network troubleshooter.
Laptop automatically connects to Verizon Fios Internet. Signal is not the best, which is why I invested in a Netgear router. I tried Windows troubleshooter, and it says it could not ID any problems. Not sure where do go from here.
