franker2407
Aug 29, 2022Aspirant
Smart Wifi Router R7000 - Laptop Installation
I purchased a new laptop. The netgear app is working on my cell phone. However, when I select the Netgear network on my laptop, it does not recognize my password (PW). I tried both the PW that came w...
- Aug 29, 2022
You have put yourself into what they call a double NAT situation. Not good. Read up on it here:
https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
The easiest solution is to access your router configuration and change the operating mode from router to wired access point. Then you can connect your router to your ONT via Ethernet cable. There are other options you can research later.
Be careful not to set your new router too physically close to the ONT as the Wi-Fi signals will interfere. Eight to ten feet is good if you can get it for separation.
franker2407
Yes, on all Qs
Kitsap
Aug 29, 2022Master
