charleyrich's avatar
charleyrich
Smartconnect on C7800?
Is there a way to use SmartConnect on the C7800 Router/modem?  I don't see it in the config screen when I log into the router.
I tried the app Genie, but I don't see it there.  The app NightHawk says it doesn't support this model.
I have manually set both the 2.4 and 5 netowrks to the same SSID.  Should I expect any unexpected side effects of that?
Thanks,
Charley
