BlogShag
Mar 06, 2021Follower
So Confusing!
OMg! This is so nerve wrecking. These people (NetGear) can't even recognize the model number of the product I have. I have an AX1800 RAX10 Wi-Fi 6 Router. And apparently they have no telephone sup...
michaelkenward
Mar 07, 2021Guru - Experienced User
Try the right section:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
BlogShag wrote:
And apparently they have no telephone support. "Great".
There may be no phone support for Netgear, but you can do it via the support portal:
Contact Us | Support | NETGEAR
First you have to register your device to confirm that it is eligible for the 90-days free support. Start here:
MyNETGEAR | Product Registration
Start a case and, with luck, they will contact you.
BlogShag wrote:
Even though I was able to hook it up to my network, their Nighthawk app will not recognize the configuration, rendering the app useless.
With so little information about what your network is, who knows why things go wrong?
You could start by telling us what happens when you try to use this Nighthawk app. Oh, and which app it is, Android or iOS.
