Wiineedmore
Jul 25, 2017Aspirant
Solid amber Internet light
Good Morning, I recently purchased and set-up this router, I have a few things plugged via Ethernet cable directly into the router. Yesterday I plugged in a new device and get a solid amber light tha...
- Jul 28, 2017Thank you, the good news I found the philips Hue bridge communicate with a rate of 100/10 Mbps. But, I couldn't find the info on the other device Samsung smartthings hub however, since they are for the same type of automation stuff I think it's safe to assume it's 100/10Mbps as well.
Thank you for your help.
ElaineM
Jul 28, 2017NETGEAR Employee Retired
Welcome to the community, Wiineedmore
Amber light means that the device plugged in is only running up to 100Mbps or less.
The LAN ports of the router are capable of up to 1000Mbps.
If it's not the device then it could be the Ethernet cable used.
- WiineedmoreJul 28, 2017AspirantThank you for the reply ElaineM I changed the Ethernet cables and added an additional device this device gets the same Amber light. The devices are a Smartthings hub and a Philips hue bridge both devices are new.
- ElaineMJul 28, 2017NETGEAR Employee Retired
Try to check at the specs of those devices if it's capable of up to 1000Mbps.
- WiineedmoreJul 28, 2017AspirantThank you, the good news I found the philips Hue bridge communicate with a rate of 100/10 Mbps. But, I couldn't find the info on the other device Samsung smartthings hub however, since they are for the same type of automation stuff I think it's safe to assume it's 100/10Mbps as well.
