Wiineedmore
Jul 25, 2017Aspirant
Solid amber Internet light
Good Morning, I recently purchased and set-up this router, I have a few things plugged via Ethernet cable directly into the router. Yesterday I plugged in a new device and get a solid amber light tha...
- Jul 28, 2017Thank you, the good news I found the philips Hue bridge communicate with a rate of 100/10 Mbps. But, I couldn't find the info on the other device Samsung smartthings hub however, since they are for the same type of automation stuff I think it's safe to assume it's 100/10Mbps as well.
Thank you for your help.
Wiineedmore
Jul 28, 2017Aspirant
Thank you for the reply ElaineM I changed the Ethernet cables and added an additional device this device gets the same Amber light. The devices are a Smartthings hub and a Philips hue bridge both devices are new.
ElaineM
Jul 28, 2017NETGEAR Employee Retired
Try to check at the specs of those devices if it's capable of up to 1000Mbps.
- WiineedmoreJul 28, 2017AspirantThank you, the good news I found the philips Hue bridge communicate with a rate of 100/10 Mbps. But, I couldn't find the info on the other device Samsung smartthings hub however, since they are for the same type of automation stuff I think it's safe to assume it's 100/10Mbps as well.
Thank you for your help.- ElaineMAug 01, 2017NETGEAR Employee Retired
Your welcome! Perhaps, contact Samsung to verify the specs.
Glad that you were able to get the details of the other one.
