Wiineedmore
Jul 25, 2017Aspirant
Solid amber Internet light
Good Morning, I recently purchased and set-up this router, I have a few things plugged via Ethernet cable directly into the router. Yesterday I plugged in a new device and get a solid amber light tha...
- Jul 28, 2017Thank you, the good news I found the philips Hue bridge communicate with a rate of 100/10 Mbps. But, I couldn't find the info on the other device Samsung smartthings hub however, since they are for the same type of automation stuff I think it's safe to assume it's 100/10Mbps as well.
Thank you for your help.
ElaineM
Jul 28, 2017NETGEAR Employee Retired
Try to check at the specs of those devices if it's capable of up to 1000Mbps.
Wiineedmore
Jul 28, 2017Aspirant
- ElaineMAug 01, 2017NETGEAR Employee Retired
Your welcome! Perhaps, contact Samsung to verify the specs.
Glad that you were able to get the details of the other one.
