Sasttv
Jan 11, 2022Follower
Solid amber light on Internet button
How do I fix a solid amber light on the Internet button and no Internet access
Jan 11, 2022Guru - Experienced User
Might be helpful to know more details of what NG product your referring too. You gave us nothing to go off.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
