Kallippide
Aug 10, 2019Guide
Solid Amber Light
Hi, I am having difficulty with a solid amber light burning continuously on my router. Yesterday I added a Sengled Hub to control my Smart bulbs. No problems with adding the hub. However, after ...
- Aug 10, 2019
As per the fine documentation, p.14 Table 2. LED and button descriptions (Continued):
Ethernet ports 1–4
The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
• Solid white or solid amber. A powered-on device is connected to the Ethernet port.
• Blinking white or blinking amber. Data is being transmitted over the port.
• Off. No powered-on device is connected to the Ethernet port.
schumaku
Aug 10, 2019Guru - Experienced User
Ethernet ports 1–4
Kallippide
Aug 10, 2019Guide
Thank you so much for your help. I didn’t realize that the amber light was okay. The router is several years old and I couldn’t find the manual anywhere. Thanks for sending me the info.
