Kallippide's avatar
Aug 10, 2019
Solid Amber Light
Hi, I am having difficulty with a solid amber light burning continuously on my router.   Yesterday I added a Sengled Hub to control my Smart bulbs. No problems with adding the hub. However, after ...
  • schumaku's avatar
    Aug 10, 2019
    As per the fine documentation, p.14 Table 2. LED and button descriptions (Continued):
    Ethernet ports 1–4
    The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
    • Solid white or solid amber. A powered-on device is connected to the Ethernet port.
    • Blinking white or blinking amber. Data is being transmitted over the port.
    • Off. No powered-on device is connected to the Ethernet port.
