shringkel
Aug 02, 2022Follower
Solid amber power light R7000
Hi people, I plugged in my R7000 after not using it for a while and I’m assuming it was updating in the background when I turned it off. Now when I switch it on all I get is a solid amber power lig...
Aug 02, 2022Guru - Experienced User
Tftp can take a few attempts and requires certain timings. I recommend trying it a few times. And if it doesn't work, the only other thing I recommend is using nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- wcalifasAug 05, 2022Prodigy
Also when you plug the router on, click on the reset button for like 20-30 seconds and see if the power light turns white and then try tftp to upload software at that point. If it doesn't turn white just run the tftp again. That amber light can also mean that the power adapter is bad so try another power adapter.
