Havok970
Apr 17, 2021Tutor
Solid orange power LED after firmware update
Greetings, My son initiated a FW update and after reboot it came up with a solid orange power LED. Cannot even get a link LED on the uplink port using a known good cable. Troubleshooting: Never ge...
antinode
Apr 17, 2021Guru
> [...] Cannot even get a link LED on the uplink port using a known good
> cable. [...]
What does Netgear call this "the uplink port"? If you mean the
WAN/Internet port, then the "Internet" LED does not behave the same as
the LAN Ethernet port-status LEDs (and so it does not indicate a simple
physical link).
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot".
> After reading countless similar issues, [...]
The non-psychics in your audience might not know what you've been
reading.
> [...] I have to wonder if they are disabling the uplink port now to
> prevent people from using the TFTP fix. [...]
Huh? The TFTP recovery scheme uses a LAN Ethernet port, not the
WAN/Internet Ethernet port.
