mpresutto63
Feb 28, 2021Guide
Solution for R7000 disconnects
My router is only about 8 months old, and we usually have to reboot it 3 times a week as it disconnetcs. I've even replaced the modem thinking that was the issue, however it still continues and I str...
Feb 28, 2021Guru - Experienced User
What actual version of the firmware are you on with the r7000?
If its not 1.0.11.116, try installing that over a hardwired connection, then do a factory reset and freshing install. Don't use a backup configuration.
or you can try the agreed upon stable firmware 1.0.9.42
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
mpresutto63
Feb 28, 2021Guide
My current firmware version is V1.0.9.88_10.2.88
- michaelkenwardMar 01, 2021Guru - Experienced User
There have been several since that one.
What happens when it "disconnects"? The wifi goes off? The Internet LED changes colour?
What modem, if there is one, sits in front of the router?
