mpresutto63
Feb 28, 2021Guide
Solution for R7000 disconnects
My router is only about 8 months old, and we usually have to reboot it 3 times a week as it disconnetcs. I've even replaced the modem thinking that was the issue, however it still continues and I str...
Mar 01, 2021Guru - Experienced User
yes you can download it from the website and install it manually.
https://www.netgear.com/support/product/R7000
mpresutto63
Mar 06, 2021Guide
I attempted to get the new firmware, and when I logged in, there were no updates and the they are saying the current firmware is V1.0.9.88_10.2.88. Thanks for all of your advice, but it's not allowing me to update any further.
- antinodeMar 06, 2021Guru
> I attempted [...]
Not a very detailed description of anything.
- michaelkenwardMar 06, 2021Guru - Experienced User
If you follow the link that plemans helpfully provided, you will find that there have been several "upgrades" since your version.
This tells you about the latest:
R7000 Firmware Version 1.0.11.116 | Answer | NETGEAR Support
That also has instructions on how to update your router.
If that fails, explain what you are doing and where it goes wrong and someone may be able to guide you through the process.
Of course, that may not fix whatever is causing your problems. In which case, you'll have to come back with enough details to allow people to fathom out what might be going wrong.
- mpresutto63Mar 06, 2021Guide
I was successfull. Thank you for all of you assistance. Stay safe!
- plemansMar 08, 2021Guru - Experienced User
Glad it worked!
